bullyjo Posted December 24, 2007 Share Posted December 24, 2007 2001 Accord: How to remove front hub bearing? I removed the tire, the caliper, the rotor, the axle nut, but the hub will not come off. I tapped on it with a hammer and it still will not move. How does this come off? Is it pressed on? Thanks for any help. Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 24, 2007 Share Posted December 24, 2007 2001 Accord: How to remove front hub bearing? I removed the tire, the caliper, the rotor, the axle nut, but the hub will not come off. I tapped on it with a hammer and it still will not move. How does this come off? Is it pressed on? Thanks for any help. on some accords the hub has to be un-bolted from behind where the axle slides into. Should be a 12 point 10mm bolts. You will have to remove the axle from the hub assembly. hope that helps, if it is not bolted then you will have to get it pressed off Link to comment Share on other sites More sharing options...
