EscoMaya Posted December 29, 2007 Share Posted December 29, 2007 i have a 96 honda accord sedan 4cyl no vtec temperature gauge doesnt work wat so ever, car runs great, blows hot air from heater, just no gauge reading, should i check temp. sensor to make sure it works or wat?? hasnt worked since i bought the car, also on the cluster the speedometer doesnt work correctly , only goes up to 20-22mph when driving falls, any clue??, i kno these issues are common, i kno like 3 other ppl that there speedometer has the same problem Link to comment Share on other sites More sharing options...
cranny Posted December 29, 2007 Share Posted December 29, 2007 make sure the sensor is plugged in first. when your car has been running long enough that you know its hot , does it put out heat when you turn it on? Link to comment Share on other sites More sharing options...
