bluedemonprelude Posted March 9, 2008 Share Posted March 9, 2008 i have an 87 prelude si which engine should i swap into it the h22 or h23 si. which one is faster off the line which one can take more pressure and abuse. what is the advantages and dissadvantages of each one. hit me with all ideas. Link to comment Share on other sites More sharing options...
chris_agu28 Posted March 9, 2008 Share Posted March 9, 2008 Okay where to start. Both motors have the same cylinder walls and such. Both are about the sameish. Both engine are heavy. H22A1 & H22A4 It has 190 HP USDM version. Has v-tec. Red line 7800. It is a 2.2 liter and pretty quick. H23 It has 197 HP USDM version. Is a Non v-tec engine. Red line 7200. It is a 2.3 liter. Basically same as above but gives up v-tec for torque. It all depends on what you are really planning on doing with the engine. Both engine can take some abuse but the weakness is the sleeves on engine. It you are planning on doing alot of work to the engine. Have in mind to get it resleeved at one time. Your engine will thank you. Are you going to be using it NA, Boost, Spray, SC, etc. This determines what you are doing with it. Here you go. Google and Wiki are your best friends on the net. http://en.wikipedia.org/wiki/Honda_H_engine Link to comment Share on other sites More sharing options...
koffeeDC2 Posted March 9, 2008 Share Posted March 9, 2008 the h23 only gets 160 hp man and 156 ft/lbs of tq Link to comment Share on other sites More sharing options...
airjordan223 Posted March 9, 2008 Share Posted March 9, 2008 cant lose with 22's bitch thats whats up Link to comment Share on other sites More sharing options...
chris_agu28 Posted March 9, 2008 Share Posted March 9, 2008 the h23 only gets 160 hp man and 156 ft/lbs of tq Yeah you were right I dunno what I was think when I was typing. Appreciate you pointing that out. cant lose with 22's bitch thats whats up ROFL +1 Link to comment Share on other sites More sharing options...
Velocifero Posted March 9, 2008 Share Posted March 9, 2008 Both redlines are supposed to be at 7200, but you can take it to 8000 easily. Link to comment Share on other sites More sharing options...
