skivy05 Posted March 9, 2008 Share Posted March 9, 2008 I have an 06 V6 accord that I recently switched to an K&N Filter. Since then I have noticed very bad gas milage....... Please help as to what I need to do or if this could even be the issue Seems odd that a Filter claiming to improve milage is actually hurting it. * Only thing I have not done... was disconnect the battery to help the ECU read the change.... could this be the issue ??? Car has 24,000 & we have always put the 87/89 Octane gas in it. No other mods. Thanks in advance Scot Link to comment Share on other sites More sharing options...
chris_agu28 Posted March 9, 2008 Share Posted March 9, 2008 That is weird. I would think the car could breath easier, so it would not work as hard. But yet more air could be coming in and the ecu might be thinking more air coming in and it has to put more fuel in to mix well with more increase in air. But that is me thinking logically Link to comment Share on other sites More sharing options...
James Matteu Posted March 10, 2008 Share Posted March 10, 2008 Take the filter off, put the OEM setup back on and see if there is any change. Link to comment Share on other sites More sharing options...
skivy05 Posted March 10, 2008 Author Share Posted March 10, 2008 I was thinking along the same line about the ECU reading more air & dumping more fuel than needed...... I'll pull the battery cable today & see how that works...... if nothing helps... guess I'll go back to OEM filter & less torque/HP....... Thanks guys for the advice. scot Link to comment Share on other sites More sharing options...
90IntegraC1 Posted March 10, 2008 Share Posted March 10, 2008 Your K&N Filter didn't do much anyway....maybe 1-2 hp... Sell it and get an OEM filter. Link to comment Share on other sites More sharing options...
James Matteu Posted March 10, 2008 Share Posted March 10, 2008 Your K&N Filter didn't do much anyway....maybe 1-2 hp... Sell it and get an OEM filter. I love how most I/H/E mods aren't able to increase the area under the power curve, but simply move the area around (add to top-end while robbing low-end). Link to comment Share on other sites More sharing options...
wannaBstuntin Posted March 10, 2008 Share Posted March 10, 2008 Take the filter off, put the OEM setup back on and see if there is any change. +1 Make sure this is the actual issue first by putting OEM back on. Link to comment Share on other sites More sharing options...
