dkzayne Posted March 17, 2008 Share Posted March 17, 2008 i have a 1992 honda accord ex and after a new ignition module,sparkplugs,spark plug wires,fuel filter,fuel pressure to ensure fuel being delivered,new distributer cap and rotor butten,battery,starter also my coolant tepeture sensor is broken so my check engine light is on and i dont know if that may affect it what it does is after the car sits for longer than an hour it will just spin over and spin and even spin some more then after about five minutes of trying it will start and if i turn it off and let it sit for a while it does it again and just spins but if i were to start it right back up it will be fine thanks zayne Link to comment Share on other sites More sharing options...
Kastigir Posted March 18, 2008 Share Posted March 18, 2008 Sounds like a Main Relay. Link to comment Share on other sites More sharing options...
chris_agu28 Posted March 18, 2008 Share Posted March 18, 2008 Sounds like a Main Relay. 1+ Link to comment Share on other sites More sharing options...
dkzayne Posted March 18, 2008 Author Share Posted March 18, 2008 well when i turn the key you hear the main relay which is under the steering column right>? well you can hear it buzz a little then click after about two seconds i just need help i am tired of poring pointless money into my car Link to comment Share on other sites More sharing options...
Kastigir Posted March 18, 2008 Share Posted March 18, 2008 How many clicks? If it isn't 3, you need a new one. Link to comment Share on other sites More sharing options...
dkzayne Posted March 18, 2008 Author Share Posted March 18, 2008 wellwhen i turn the key to turn on the lights on the dash on you can hear it go humm for a few seconds then you hear it click then you dont hear from it no more so i guess only one click and might i ask what website i could order a new one from zayne Link to comment Share on other sites More sharing options...
Kastigir Posted March 19, 2008 Share Posted March 19, 2008 Just go to your local Honda dealer. They will have to order it. Costs about 75 bucks. Link to comment Share on other sites More sharing options...
dkzayne Posted March 24, 2008 Author Share Posted March 24, 2008 i bought a new main relay and its still doing it Link to comment Share on other sites More sharing options...
lceah Posted March 24, 2008 Share Posted March 24, 2008 your timing belt ok? pull the code and tell us the code! also, is this a manual or auto? I didn't see it mentioned anywhere... Link to comment Share on other sites More sharing options...
dkzayne Posted March 24, 2008 Author Share Posted March 24, 2008 no the timing belt looks okay and it is an automatic and if you are talking about the check engine code it flashes six times which is the coolant tempeture sensor Link to comment Share on other sites More sharing options...
James Matteu Posted March 24, 2008 Share Posted March 24, 2008 no the timing belt looks okay and it is an automatic and if you are talking about the check engine code it flashes six times which is the coolant tempeture sensor You need to take it up to Duval Honda this Saturday and pay the $40 to solve this one, before you buy anything else. Link to comment Share on other sites More sharing options...
dkzayne Posted March 24, 2008 Author Share Posted March 24, 2008 why this saturday??? and what all do they check for there? Link to comment Share on other sites More sharing options...
James Matteu Posted March 24, 2008 Share Posted March 24, 2008 I figured you might be to busy during the week. Hopefully they can figure out what is wrong with your car considering you have replaced everything I would imagine to be the source of this type of problem short of a: new fuel pump, combination switch, and positive battery harness. So I am scratching my head, and have yet to see someone come up with a logical response to your issue. How do your wires look? Do you have the Helms Service Manual for your car? I could poke around your engine bay and dash, but I am not sure I will be of any help since I am really not familiar with this electronic setup (I had a 3G Accord and now a 5G Accord, but never a 4G). So I really know more about OBD-0 and OBD-II, compared to my knowledge of OBD-I. Link to comment Share on other sites More sharing options...
James Matteu Posted March 24, 2008 Share Posted March 24, 2008 a new ignition module Is that the same thing as the ignition coil? Or are you referring to something else. Link to comment Share on other sites More sharing options...
Kastigir Posted March 25, 2008 Share Posted March 25, 2008 Have you verified that you're getting fuel and spark? Link to comment Share on other sites More sharing options...
dkzayne Posted March 26, 2008 Author Share Posted March 26, 2008 yes i am getting spark and i know im getting fuel and for you james the module is inside my distributer and no i havent changed the coil which i do know where it is at Link to comment Share on other sites More sharing options...
Kastigir Posted March 26, 2008 Share Posted March 26, 2008 yes i am getting spark and i know im getting fuel and for you james the module is inside my distributer and no i havent changed the coil which i do know where it is at How do you know you're getting fuel? An engine needs 3 things to run. Fuel, ignition, and compression. If you're positive you've got the first 2, then the 3rd is your problem. I would recheck. Link to comment Share on other sites More sharing options...
dkzayne Posted March 26, 2008 Author Share Posted March 26, 2008 well i know i have compression because when the car spins over you can hear a constant sound and i know what it would sound like if one of the pistons have low compression due to a friend of mines old car so i know i have constant compression Link to comment Share on other sites More sharing options...
dkzayne Posted April 9, 2008 Author Share Posted April 9, 2008 i have good news guys i got bored today and decided to tinker with my car when i realized my timing and firing order was off so i took all day to fix it and when i got everything put together i went to start it and it was great it started right up well thank you all for the help Link to comment Share on other sites More sharing options...
