mohondaman Posted May 31, 2008 Share Posted May 31, 2008 I am receiving a E-1 on the display on my radio when I try to switch to the cd changer. Any ideas for a fix? I need to get some cd's out of the changer. Thanks for the help. Link to comment Share on other sites More sharing options...
James Matteu Posted May 31, 2008 Share Posted May 31, 2008 According to the owner's manual (the one in the glove box), there are a few error messages that can pop up, but you seem to have the one of two that requires the dealer to intervene. Indication: Cause: Solution E-01: Disc-changer malfunction: Consult your Honda dealer The other is: E-EE: Misconnection or disconnection of CD Changer: See you Honda dealer. I checked the glove box manual (P/N 00X31-SV1-6302) and the Electrical Troubleshooting Manual (P/N 61SV405EL) and neither offer any assistance. Keep in mind; if you end up needing a replacement, any Alpine 8-DIN 6-disc changer will work with your head unit. The appropriate adaptor cables are available on the internet. Link to comment Share on other sites More sharing options...
CDelgado Posted June 18, 2008 Share Posted June 18, 2008 I am receiving a E-1 on the display on my radio when I try to switch to the cd changer. Any ideas for a fix? I need to get some cd's out of the changer. Thanks for the help. I had a recent similar problem with my cd changer. I reset the cd changer(there's a reset button in the lower back part) or your could unplug the cd changer and try again. That fixed my problem andneverhad it again. It's been like 8 months. Good luck! Link to comment Share on other sites More sharing options...
larsonbp Posted February 10, 2012 Share Posted February 10, 2012 The error that your receiving is because of a disc changer malfunction. I had the same problem with my 2005 accord and came across a seller that sells the blocks online. (the block includes the disc changer and radio components.) http://www.cd4car.com/ The people at the company were very helpful in making sure that I purchased the right one, I spoke with someone on the phone and they helped me match it up with the face ID on my radio. Here is a video I watched that helped me to install it myself without any problems. Link to comment Share on other sites More sharing options...
