norrisboat2 Posted June 10, 2008 Share Posted June 10, 2008 Hi all, Im stumped. I cant figure out why passenger side accord coupe window will not go up or down. My window wont go up or down. There is no noise coming from the regulator signifing it has power. I tested the switch before removing anything. I had power to the switch before I did anything. I figured since I have power to the switch and no noise from the motor by activating the switch, that it must be the motor. I ordered and plugged in the new motor. I didnt install it yet because I wanted to see if it was the true problem. I get no movement of the slide or any noise from the motor. Now I notice I no longer have and power to the switch using my multimeter. engaged or disengaging the switch i dont recieve any power. I ordered a new switch knowing its probably not the problem. Install the switch no movement of the slide/regulator. I swapped the cooling fan relay with the power window relay since they are the same. Still no movement from the slide/regulator. Checked fuses. They are all good. Drivers side window controller also doesnt power the passenger side window. The drivers side window works fine. Does anyone have an idea why its not working? I had power to the switch before replacing the regulator and now i dont. Does anyone understand what else could have gone wrong? Thanks, Norrisboat Link to comment Share on other sites More sharing options...
James Matteu Posted June 10, 2008 Share Posted June 10, 2008 Poor ground or a bad connection. I don't mean to be vague, but you need to hunt this one down, one connection at a time. Link to comment Share on other sites More sharing options...
lceah Posted June 10, 2008 Share Posted June 10, 2008 bad ground... some wire somewhere hanging hitting something... gl Link to comment Share on other sites More sharing options...
norrisboat2 Posted June 10, 2008 Author Share Posted June 10, 2008 bad ground... some wire somewhere hanging hitting something... gl Yeh, i was hoping somebody would have the holy grail fix instead of having to finger through where the bad ground was. Thanks for the help. Ill work on it some more tomorrow. Ill still await the holy grail fix in case someone knows it. Thanks, Norris Link to comment Share on other sites More sharing options...
airjordan223 Posted June 10, 2008 Share Posted June 10, 2008 if youre looking for the holy grail, youre going to have to talk to Dr. Jones. in the meantime, search for that ground wire Link to comment Share on other sites More sharing options...
lceah Posted June 10, 2008 Share Posted June 10, 2008 hahahaha Link to comment Share on other sites More sharing options...
norrisboat2 Posted June 10, 2008 Author Share Posted June 10, 2008 Ok, so i goofed. I used a bad ground when i was measuring for power at the switch and the motor. I have power to the switch. I also have power to the wiring harness connection(where the regulator plugs into) when clicking the switch one direction. The other direction on the switch doesnt produce a voltage result(im assuming its because its for down window operation, not sure though). Did I get a dead on arrival motor? What else could it be? Thanks, Norris Link to comment Share on other sites More sharing options...
James Matteu Posted June 11, 2008 Share Posted June 11, 2008 The other direction on the switch doesnt produce a voltage result(im assuming its because its for down window operation, not sure though). DC Circuit my friend, motors only work in the direction of the Electromotive Force. Reverse your leads, you will find your missing voltage. Link to comment Share on other sites More sharing options...
