nater Posted June 19, 2008 Share Posted June 19, 2008 I have a 1989 accord sei fuel injected 2.0L. Recently while driving the engine light comes on and when I stop turn the car off and restart the light resets. but comes back on after I start driving again. Also lately while sitting at stop lights the car will suddenly almost stall but then pick up rpms. And sometimes after driving on the highway and I stop the car when I try to start it, it will turn over but will not fire, after letting it sit for 20 min. or so I turn the key and it fires right up. In the past month I have gone thru 2 rebuilt alternaters. any ideas ???? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted June 19, 2008 Share Posted June 19, 2008 Pull the code for the cel and fix the problem. Clear the code and see if it comes back. Link to comment Share on other sites More sharing options...
nater Posted June 19, 2008 Author Share Posted June 19, 2008 I have a 1989 accord sei fuel injected 2.0L. Recently while driving the engine light comes on and when I stop turn the car off and restart the light resets. but comes back on after I start driving again. Also lately while sitting at stop lights the car will suddenly almost stall but then pick up rpms. And sometimes after driving on the highway and I stop the car when I try to start it, it will turn over but will not fire, after letting it sit for 20 min. or so I turn the key and it fires right up. In the past month I have gone thru 2 rebuilt alternaters. any ideas ??? ? what code reader is used for this year and where does it plug in? Link to comment Share on other sites More sharing options...
sm0keyouwith my acc0rd Posted July 22, 2008 Share Posted July 22, 2008 obd1 and it could be you have a bad battery check the code at any advanced auto or any major auto part store Link to comment Share on other sites More sharing options...
skulptr Posted July 25, 2008 Share Posted July 25, 2008 might be easier to just get the cel codes off your ecu rather than tryin to chase down an obd1 reader. Link to comment Share on other sites More sharing options...
vM DaNK Posted August 19, 2008 Share Posted August 19, 2008 reset it Link to comment Share on other sites More sharing options...
Markie66 Posted October 4, 2008 Share Posted October 4, 2008 how do i find and clear the cel code...what is that ?? i am a newbie at this Link to comment Share on other sites More sharing options...
Markie66 Posted October 4, 2008 Share Posted October 4, 2008 or how do i reset the ecu ?? Link to comment Share on other sites More sharing options...
Kastigir Posted October 4, 2008 Share Posted October 4, 2008 or how do i reset the ecu ?? Unplug the battery for a bit. Also, I think you can pull a fuse under the hood. Link to comment Share on other sites More sharing options...
Markie66 Posted October 4, 2008 Share Posted October 4, 2008 Unplug the battery for a bit. Also, I think you can pull a fuse under the hood. thanks Kas i will try t hat tomm morning...should i unplug the battery for a few hrs ..or maybe a day ?? Link to comment Share on other sites More sharing options...
Kastigir Posted October 4, 2008 Share Posted October 4, 2008 thanks Kas i will try t hat tomm morning...should i unplug the battery for a few hrs ..or maybe a day ?? Shouldn't need to unplug it for more than a couple of minutes. Link to comment Share on other sites More sharing options...
