jerrodh Posted July 21, 2008 Share Posted July 21, 2008 Anyone got good ideas that are long lasting. Cause the hardware I've used continuely keeps coming undone through normal driving. Least when i was driving it. Wouldnt mine doing it right this time. Link to comment Share on other sites More sharing options...
Pballer2005 Posted July 21, 2008 Share Posted July 21, 2008 are the bolts coming loose from vibrations? would some thread lock stand up to that? i just cranked the f*ck out of mine and they've held for 2 months now... Link to comment Share on other sites More sharing options...
mpearce1974 Posted July 21, 2008 Share Posted July 21, 2008 Anyone got good ideas that are long lasting. Cause the hardware I've used continuely keeps coming undone through normal driving. Least when i was driving it. Wouldnt mine doing it right this time. Show us a pic of how you have it mounted? Link to comment Share on other sites More sharing options...
jerrodh Posted July 21, 2008 Author Share Posted July 21, 2008 Yeah but Im not going to lie its some pretty weak crap I got. How big are your bolts and how'd you mount it exactly? Link to comment Share on other sites More sharing options...
BlackEK Posted July 21, 2008 Share Posted July 21, 2008 Drill through floor and bottom of the box, and use 3/8 bolts with flat washers and locking washers. put silicone on the heads or nuts in the box to seal the air. Link to comment Share on other sites More sharing options...
TLontheDL Posted July 25, 2008 Share Posted July 25, 2008 Link to comment Share on other sites More sharing options...
jerrodh Posted July 25, 2008 Author Share Posted July 25, 2008 Thats honestly the exact setup I had. Two of them and they didint last a week without needing to be screwed in, etc. I'm thinking about making a new trunk floor. Cutting a peice of plywood and just reglueing the Del Sol trunk floor down ontop of it. Then I can bolt and nut straight to my box if necessary. Link to comment Share on other sites More sharing options...
TLontheDL Posted July 25, 2008 Share Posted July 25, 2008 go beneath your car and put a bult on the other end of the screw, along with a rubber washer. Link to comment Share on other sites More sharing options...
CBRF4i Posted July 26, 2008 Share Posted July 26, 2008 False floors are the way to do it Not only gives you a good base to mount the enclosure but also gives you a nice means to hide all the wiring. Link to comment Share on other sites More sharing options...
TLontheDL Posted July 27, 2008 Share Posted July 27, 2008 is that your setup? Link to comment Share on other sites More sharing options...
Pballer2005 Posted July 27, 2008 Share Posted July 27, 2008 seems like that fiber board would jump around without anything holding it down. Link to comment Share on other sites More sharing options...
CBRF4i Posted July 27, 2008 Share Posted July 27, 2008 its all locked in place. . its not going anywhere, you can flip my truck upside down and its wont move lol and yes TL thats my setup Link to comment Share on other sites More sharing options...
Tubbith Posted July 27, 2008 Share Posted July 27, 2008 seems like that fiber board would jump around without anything holding it down. Cuz that sub(which im guessing is a 15" from the looks of it, and has a pretty decent sized magnet on it) and the amps are holding it down at all... Link to comment Share on other sites More sharing options...
CBRF4i Posted July 27, 2008 Share Posted July 27, 2008 Cuz that sub(which im guessing is a 15" from the looks of it, and has a pretty decent sized magnet on it) and the amps are holding it down at all... offensive. . . 18"s is how i roll :drool: Thats a 6.5 cu^ft box in the ass of a Suburban if that helps change the scope of the diameter Link to comment Share on other sites More sharing options...
Tubbith Posted July 27, 2008 Share Posted July 27, 2008 yeah.. i knew it was BIG as FU*K... just didnt realize that was a burban... plus im drunk.. but now it all makes sense.. im guess that woofer weights damn near 80lbs.. if not a bit more.. Link to comment Share on other sites More sharing options...
cranny Posted July 27, 2008 Share Posted July 27, 2008 try strips of velcro in between box and floor running front to back. Link to comment Share on other sites More sharing options...
jerrodh Posted July 27, 2008 Author Share Posted July 27, 2008 Thats a good idea TBH. I might do both, two brackets in the back and bolting it up from under the car then do some velcro just to try and give the brackets some relief under heavy pressure. Link to comment Share on other sites More sharing options...
CBRF4i Posted July 27, 2008 Share Posted July 27, 2008 yeah.. i knew it was BIG as FU*K... just didnt realize that was a burban... plus im drunk.. but now it all makes sense.. im guess that woofer weights damn near 80lbs.. if not a bit more.. The false floor is bolted to the bottom of the cargo area, the box is bolted to the false floor. I just make sure to put the strap downs in inconspicuous places so they dont stand out. Link to comment Share on other sites More sharing options...
