speaker_king Posted July 26, 2008 Share Posted July 26, 2008 I have a 1993 accord lx and the throttle controll sensor is bad, when its in park or nuetral it rapidly idles up n down, and because its on the air intake, it constricts the air from being sucked in and wont start half the time. Does anybody know how much they cost or what other year cars will work on it? Link to comment Share on other sites More sharing options...
sm0keyouwith my acc0rd Posted July 26, 2008 Share Posted July 26, 2008 92 accord lx will work same engine same car Link to comment Share on other sites More sharing options...
skulptr Posted July 26, 2008 Share Posted July 26, 2008 do you have a junk yard around you? a self service parts lot or something? if so, you can replace it for maybe ten bucks at most. if not.. its gonna get expensive and any 90-93 are going to work. just make sure its for the f22 2.2L, thats all Link to comment Share on other sites More sharing options...
speaker_king Posted July 26, 2008 Author Share Posted July 26, 2008 Iv already tried all the ones from the junk yards. And the ones that they had were no good also. Link to comment Share on other sites More sharing options...
skulptr Posted July 26, 2008 Share Posted July 26, 2008 nto possible, how many did you try... and if that didnt work, you need to check your speed sensor. if its bad, the car will not idle right and may not even start. Link to comment Share on other sites More sharing options...
speaker_king Posted July 27, 2008 Author Share Posted July 27, 2008 Everyone at every junkyard, altho most of them were already gone. So about 6. Where is the speed sensor, and what does it look like like? Link to comment Share on other sites More sharing options...
speaker_king Posted July 30, 2008 Author Share Posted July 30, 2008 Just an update, i still need the throttle sensor, but the reason it wont start half the time is because one of the wires inside the distributor is almost into Link to comment Share on other sites More sharing options...
skulptr Posted July 30, 2008 Share Posted July 30, 2008 one of the wires in the distributor is what? and the speed sensor should be located in the tranny mounted in the side, i will check the books when i get home tomorrow and see waht i can see Link to comment Share on other sites More sharing options...
speaker_king Posted July 31, 2008 Author Share Posted July 31, 2008 its almost in two pieces, hahaha Oh and i have the imported F20A motor, and it has an external coil pack Link to comment Share on other sites More sharing options...
Turtlehead Posted August 8, 2008 Share Posted August 8, 2008 Probably your TPS sensor is dirty. Clean that and see where you stand. Link to comment Share on other sites More sharing options...
