md7323 Posted July 29, 2008 Share Posted July 29, 2008 Hi to all, I have a 1986 Accord LXi fuel injected with 178,000 and I seam to be loosing coolant from somewhere. I do not have any leaks that are noticable nothing on the groud, but I will lose three quarters of the fulid after driving ~ 300 miles. I did let it sit in the driveway the other day for well over a half hour and not a drop. I thank you all in advance, Link to comment Share on other sites More sharing options...
James Matteu Posted July 29, 2008 Share Posted July 29, 2008 Pressure test the radiator. Your leak will show itself. Link to comment Share on other sites More sharing options...
md7323 Posted July 29, 2008 Author Share Posted July 29, 2008 Thanks for the quick reply, I have never done this before is there a defined procedure or just compressed air in the radiatior opening i.e plug with air being suppied through hole in the middle. Thanks again, Link to comment Share on other sites More sharing options...
James Matteu Posted July 29, 2008 Share Posted July 29, 2008 In my case, I purchased a $160 hand pump with a fitting to attach to serveral different types of radiators. The hand pump has a gauge calibrated in psi and mmHg. I apply pressure and wait for the needle to drop, a check valve prevents the pressure from dropping when I am not pumping. Often, a leak will present itself when I apply about 12psi to a radiator; it will start to weep or drip under that pressure. I cannot advise you how to proceed without that equipment. Link to comment Share on other sites More sharing options...
Turtlehead Posted August 8, 2008 Share Posted August 8, 2008 You may also want to pressure check the cylinders at TDC for each one at 100 psi. Could be the head gasket is failing. Link to comment Share on other sites More sharing options...
cranny Posted August 8, 2008 Share Posted August 8, 2008 if your losing coolant and not on the ground and no sign of where its going , its surely a headgasket. Link to comment Share on other sites More sharing options...
