cpico Posted August 19, 2008 Share Posted August 19, 2008 I have a 1997 accord se 2dr with 165000. I have never had a problem with the car overheating but recently after climbing into the mountains about 6000ft the car was getting overheated and steam/coolant was escaping from the overflow. The cooling fan was not coming on and then later at lower elevation it did again. Once it cooled down I checked the radiator and it was empty. I refilled it and again it overheated only when climbing and just loses water or coolant through the overflow there is no other visible sign of water leaking. Would this be a thermostat problem or something else. Not a mechanic but need help! cpico Link to comment Share on other sites More sharing options...
mpearce1974 Posted August 19, 2008 Share Posted August 19, 2008 I have a 1997 accord se 2dr with 165000. I have never had a problem with the car overheating but recently after climbing into the mountains about 6000ft the car was getting overheated and steam/coolant was escaping from the overflow. The cooling fan was not coming on and then later at lower elevation it did again. Once it cooled down I checked the radiator and it was empty. I refilled it and again it overheated only when climbing and just loses water or coolant through the overflow there is no other visible sign of water leaking. Would this be a thermostat problem or something else. Not a mechanic but need help! cpico Water pump? Can you tell if there is any flow? Link to comment Share on other sites More sharing options...
Hatch92 Posted August 20, 2008 Share Posted August 20, 2008 sounds like a water pump. however i wouldn't say that's the cause, but my only guess. Link to comment Share on other sites More sharing options...
Routeg35 Posted August 20, 2008 Share Posted August 20, 2008 check thermostat, fan sensor, and radiator. radiator may be clog. and dont add coolant to a hot engine unless engine is idling. if you add coolant to a hot engine and not running engine you can crack your engine head. Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted August 20, 2008 Share Posted August 20, 2008 id change the thermo to a cooler thermo, so it opens up at cooler temps to keep your car cooler, and i would have guessed a loose or leaking hose, but you said there was no leaks, so im stumped... Link to comment Share on other sites More sharing options...
