blkCouPe97 Posted September 1, 2008 Share Posted September 1, 2008 like it sounds fine when the engine is off when the engine is on it get loud n like the higher my Rpms the higher the pitch goes,,, i can only listen to music real loud lmfao Link to comment Share on other sites More sharing options...
Kastigir Posted September 1, 2008 Share Posted September 1, 2008 like it sounds fine when the engine is off when the engine is on it get loud n like the higher my Rpms the higher the pitch goes,,, i can only listen to music real loud lmfao Bad ground. Reground your amps somewhere else. Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted September 1, 2008 Share Posted September 1, 2008 +10 on bad ground, find a better surface to reground on ::EDIT:: i dont want to fully cosign... or you could sand down better where its already grounded Link to comment Share on other sites More sharing options...
TLontheDL Posted September 1, 2008 Share Posted September 1, 2008 be sure that there is no car paint in that area. Link to comment Share on other sites More sharing options...
duffmanaudio Posted September 26, 2008 Share Posted September 26, 2008 What does your system consist of? Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 26, 2008 Share Posted September 26, 2008 My Del Sol dod same damn thing, no matter what I did, so I wound up buying filters and had no problems after that! Link to comment Share on other sites More sharing options...
