zoltron30 Posted September 20, 2008 Share Posted September 20, 2008 hi guys my 2001 honda accord needs front lower ball joints. honda is charging over 400.00 including labor and canadian tire wants around 325.00. i dont know how to install them myself so i was thinking of letting my local mechanic install them for me at a much cheaper rate. just wondering if i should my mechanic do the job or have it done professionally? thanks! Link to comment Share on other sites More sharing options...
Kegger Posted September 20, 2008 Share Posted September 20, 2008 Ball joints are balljoints. Your mechanic could do just as good a job as the other two and you save a good chunk of change at the same time. Link to comment Share on other sites More sharing options...
Jeffro Posted September 20, 2008 Share Posted September 20, 2008 Ball joints are balljoints. Your mechanic could do just as good a job as the other two and you save a good chunk of change at the same time. +1 to Kegger. Link to comment Share on other sites More sharing options...
James Matteu Posted September 20, 2008 Share Posted September 20, 2008 I say lube them and see where you stand. Link to comment Share on other sites More sharing options...
Velocifero Posted September 26, 2008 Share Posted September 26, 2008 I say lube them and see where you stand. And replace the crapty rubber bushing with a polyurethane bushing. Might last longer than you think. Link to comment Share on other sites More sharing options...
