quest Posted September 28, 2008 Share Posted September 28, 2008 Can someone tell me where the Relay for the power locks is located??? Link to comment Share on other sites More sharing options...
Turtlehead Posted September 29, 2008 Share Posted September 29, 2008 Can someone tell me where the Relay for the power locks is located??? Relay??? I think you are after one of two things. 1. In the underhood fuse box power should run first through fuse 15 and then through fuse 38 (20A). If your locks are not working check that first. 2. The power door lock control unit may have failed (it is located behind the drivers side inner door panel) 3. Or, there is always the chance for bad ground or faulty wiring Good luck. Link to comment Share on other sites More sharing options...
