cbow2890 Posted October 24, 2008 Share Posted October 24, 2008 i am installing my turbo onto my 95 accord and i need to know where all of the vacuum and boost lines connect to. like from the blow off valve and the wastegate. please help! Link to comment Share on other sites More sharing options...
James Matteu Posted October 24, 2008 Share Posted October 24, 2008 You will get more replies with more information. Link to comment Share on other sites More sharing options...
cranny Posted October 24, 2008 Share Posted October 24, 2008 what spring in the wastegate? what boost you running? what kind of boost controller are you running? Link to comment Share on other sites More sharing options...
lastresort576 Posted October 24, 2008 Share Posted October 24, 2008 what spring in the wastegate? what boost you running? what kind of boost controller are you running? for the most part does it matter? wastegate will be run off of the turbo's compressor housing, BOV will be run off either a T'd source on the IM or with the use of a vacuum manifold T'd off of the brake booster before the check valve(closer to the IM) Link to comment Share on other sites More sharing options...
Sport Injection Posted October 25, 2008 Share Posted October 25, 2008 It doesn't matter. Run a Vac line from the BOV to the Intake manifold. As far as the Wastegate goes, Tap the outlet of your compressor housing, run a line from there to the boost controller, and then to the wastegate. Simple as that. Link to comment Share on other sites More sharing options...
