md7323 Posted November 5, 2008 Share Posted November 5, 2008 I am in the process of completing a head gasket job on a 1986 accord LXI. I am having difficulties putting the black hose under the manifold on the box that looks to be resting in the rear motor mount; the hoes came off the box and not off the manifold. My question, if I do not have that hose tight to what looks like part of the PVC system what problems will I have. This hose could not have been put in a better location, why make it easy for you to get at. Engineers:( Thank you in advance, MD7323 Link to comment Share on other sites More sharing options...
CleanGSR Posted November 5, 2008 Share Posted November 5, 2008 If it's the PCV then you could end up with bad idling and/or stalling, among other things. Plus having the PCV system not intact is bad for pollution/environment. You should really try to get that hooked back up. Could you have not hooked it up before putting the head all the way back down? (If what I'm saying makes sense). Link to comment Share on other sites More sharing options...
