scaryjello Posted January 14, 2009 Share Posted January 14, 2009 I recently installed a HID kit in my 95 Accord. I used a relay harness and everything to make sure i wouldnt melt anything. My lights turn on and work fine. However, the passenger side HIGH beam comes on with the headlights. If i turn the HIGH beams on, both sides come on but are very dim, but once i turn them off, the passenger one still stays on and is bright like it should be. Does anyone know what this problem could be? Thank You Link to comment Share on other sites More sharing options...
James Matteu Posted January 14, 2009 Share Posted January 14, 2009 Where did you tap your harness for an input voltage to the relay? How do you have your ballast connected? Did you follow a circuit diagram? Can you provide a link to the diagram you followed? Link to comment Share on other sites More sharing options...
scaryjello Posted January 14, 2009 Author Share Posted January 14, 2009 Where did you tap your harness for an input voltage to the relay? How do you have your ballast connected? Did you follow a circuit diagram? Can you provide a link to the diagram you followed? Well I didn't follow a diagram. I ordered a harness that was already made from the company. I believed I figured out the problem tho. I unplugged both sides of the HID wire harness to the factory because what kept happening everytime I turned on the headlights, I blew a left headlight fuse under the hood. So then I only plugged in the right side n turned it on and it nothing blew. Then I plugged in the other side and it blew the fuse. I'm just going to switch sides with the ballast and see what happens then Link to comment Share on other sites More sharing options...
Repsol Posted January 15, 2009 Share Posted January 15, 2009 You may have switched some wires up. Link to comment Share on other sites More sharing options...
