blackwater Posted January 24, 2009 Share Posted January 24, 2009 Recently my 91 Accord started going in and out of overdrive - then suddenly last night the "S" light starts blinking and now no overdrive. The speed sensor was replaced last year. I did notice today the engnie temp seems a bit lower than usual by about 1/8 inch on the gague even after driving 20 or so minutes. I cleaned all the connectons coming off the tranny that I could easily get to and the fluid level is fine and was changed about 3 or 4 years ago. Any ideas or anything else I should check? I can't get to a parts store till tomorrow and in the interim I had thought about partially blocking the radiator to get the temp up and see if that's the problem...keeping a close eye on the temp gague of course! Link to comment Share on other sites More sharing options...
James Matteu Posted January 26, 2009 Share Posted January 26, 2009 Pull the Malfunction Indicator Light code. Link to comment Share on other sites More sharing options...
blackwater Posted January 26, 2009 Author Share Posted January 26, 2009 Pull the Malfunction Indicator Light code. Sorry - not sure what you mean. Are you talking about counting the number of times the "S" light flashes like a chk engine light? If so how do you so this - or are you talking about the chk engine light? Link to comment Share on other sites More sharing options...
James Matteu Posted January 26, 2009 Share Posted January 26, 2009 Are you talking about counting the number of times the "S" light flashes like a chk engine light? If so how do you so this... Yes, count the number of times the "S" light flashes. Like Check Engine Light (MIL), the number and frequence of flashes correspondes to a specific Diagnostic Trouble Code (DTC). On the 1994-97 Honda Accord: The same service connector used to pull DTCs from the Engine Control Module (ECM) is used to pull DTCs from the Transmission Control Module (TCM) and ABS control module. In other words, if I have a: Check Engine Light, Flashing D, and a ABS light on, by closing the diagnostic circuit, I make all three flash their codes simultaneously. The codes cycle on the ECM and TCM. The ABS control module will not cycle a code for an intermittent problem. Back to your car: This may or may not be how to pull the codes in your car, but the point is that if you know how to pull codes from the check engine light, do the same for your transmission. Link to comment Share on other sites More sharing options...
blackwater Posted January 29, 2009 Author Share Posted January 29, 2009 Yes, count the number of times the "S" light flashes. Like Check Engine Light (MIL), the number and frequence of flashes correspondes to a specific Diagnostic Trouble Code (DTC). On the 1994-97 Honda Accord, the same service connector is used to pull the DTCs from the Engine Control Module (ECM) are used to pull codes from the Transmission Control Module (TCM), among other systems. In other words, on the 1997 Accord, if you have a Check Engine Light, Flashing D, and a ABS light on, closing the diagnostic circuit will make all three flash their codes simultaneously; don't worry, the codes cycle on the ECM and TCM, some codes in the ABS control do not. This may or may not be how to pull the codes in your car, but the point is that if you know how to pull codes from the check engine light, do the same for your transmission. Ah! Ok - thanks, that makes sense. I'm going to try to replace the solenoids tomorrow with ones off my 93 SE and see if that fixes it. My mechanic seems to thik it couldn't hurt... Link to comment Share on other sites More sharing options...
Kastigir Posted January 29, 2009 Share Posted January 29, 2009 Instead of randomly replacing parts, why not pull the code and see what it is you need? Link to comment Share on other sites More sharing options...
blackwater Posted January 29, 2009 Author Share Posted January 29, 2009 Instead of randomly replacing parts, why not pull the code and see what it is you need? Do I not need some kind of special code reader? Link to comment Share on other sites More sharing options...
James Matteu Posted January 29, 2009 Share Posted January 29, 2009 No, you do not need a special code reader. Yes, count the number of times the "S" light flashes. Like Check Engine Light (MIL), the number and frequence of flashes correspondes to a specific Diagnostic Trouble Code (DTC). On the 1994-97 Honda Accord: The same service connector used to pull DTCs from the Engine Control Module (ECM) is used to pull DTCs from the Transmission Control Module (TCM) and ABS control module. In other words, if I have a: Check Engine Light, Flashing D, and a ABS light on, by closing the diagnostic circuit, I make all three flash their codes simultaneously. The codes cycle on the ECM and TCM. The ABS control module will not cycle a code for an intermittent problem. Back to your car: This may or may not be how to pull the codes in your car, but the point is that if you know how to pull codes from the check engine light, do the same for your transmission. On my car, the service connector is a 2-pin connector with the wires connected (it is a jumper wire). The diagnostic circuit is closed by connecting the service connector. You can do the same thing with a jumper wire. Link to comment Share on other sites More sharing options...
blackwater Posted January 29, 2009 Author Share Posted January 29, 2009 No, you do not need a special code reader. On my car, the service connector is a 2-pin connector with the wires connected (it is a jumper wire). The diagnostic circuit is closed by connecting the service connector. You can do the same thing with a jumper wire. Throwing on a coat to go see if I can find mine! Link to comment Share on other sites More sharing options...
James Matteu Posted January 29, 2009 Share Posted January 29, 2009 On mine, it is a blue connector under the glove box. Link to comment Share on other sites More sharing options...
