pauly0 Posted February 9, 2009 Share Posted February 9, 2009 My '93 Accord LX almost dies out when i come to a stop. Similar symptoms occurred when my fuel filter was clogged. I changed the fuel filter, plugs, and rotor and cap in the last six months. I was told to take out the AIC and spray w/ carburator cleaner. Any other suggestions or does this seem like a the right diagnosis? Link to comment Share on other sites More sharing options...
itsahonda Posted February 11, 2009 Share Posted February 11, 2009 My '93 Accord LX almost dies out when i come to a stop. Similar symptoms occurred when my fuel filter was clogged. I changed the fuel filter, plugs, and rotor and cap in the last six months. I was told to take out the AIC and spray w/ carburator cleaner. Any other suggestions or does this seem like a the right diagnosis? Along with the other things you changed, perhaps you should check your PCV valve. A clogged one can cause idle problems. Replacement is cheap and easy. Link to comment Share on other sites More sharing options...
nnoossss Posted February 27, 2009 Share Posted February 27, 2009 My '93 Accord LX almost dies out when i come to a stop. Similar symptoms occurred when my fuel filter was clogged. I changed the fuel filter, plugs, and rotor and cap in the last six months. I was told to take out the AIC and spray w/ carburator cleaner. Any other suggestions or does this seem like a the right diagnosis? My 88 accord does that only when its raining for some reason i think something sticks or something idk because it will try to die when im slowin down or come to a complete stop very rarely though. Do u kno wat could b wrong with it. Link to comment Share on other sites More sharing options...
