algeonarock Posted March 13, 2009 Share Posted March 13, 2009 Please help. I am currently trying to re-wire the climate control system in my 98 civic. I looked into doing the full swap, and decided against it. But still, I would like the dials to work.(yes I already know the temp control won't) has anybody done this, and if so, does anybody have a diagram for the two harnesses so that I know which wires to connect? edit: ok, so for the most part the cords are 'plug and play', the air 'direction' controller works, all the lights work, the a/c works, the recycle air works. On the 98, the speed control is manipulated by 4 live wires and a ground, and it turns on the speed depending on which one you ground. on the 99 harness, I can't seem to find wires that match up with this? any ideas? Link to comment Share on other sites More sharing options...
