wingstealer Posted March 22, 2009 Share Posted March 22, 2009 my 91 accord lx has this weird and yet ever annoying problem when i first start the car it goes to 3k and doesnt want to come down i tried everything IACV, FTIV, reseting the ecu unplugging the IACV ajusting the idle screw everything the book says i have done but it doesnt go down the only time i can see results is if i unplug the IACV and leave it unplugged it dropes to 2k and surges to 2.2k to 1.8k never ever goes down to the recommended 700-800 idle rpms never Link to comment Share on other sites More sharing options...
94typersol Posted March 30, 2009 Share Posted March 30, 2009 tell them about your port job jeremy. Link to comment Share on other sites More sharing options...
nnoossss Posted March 31, 2009 Share Posted March 31, 2009 i have an 88 accord wen i first turn it on it does the same thing, now its carborated so idk how dats gona affect u since i doubt urs is carborated. What i do to get rid of it is tap the gas pedal and most of the time it will go down or i can just pop it into drive and tap the pedal a lil and itll go away. Link to comment Share on other sites More sharing options...
Rick B. Posted March 31, 2009 Share Posted March 31, 2009 what happens when the motor warms up? and have you adjusted the throttle cable. loosening that will drop the rpms. Link to comment Share on other sites More sharing options...
James Matteu Posted April 2, 2009 Share Posted April 2, 2009 i have an 88 accord wen i first turn it on it does the same thing, now its carborated so idk how dats gona affect u since i doubt urs is carborated. What i do to get rid of it is tap the gas pedal and most of the time it will go down or i can just pop it into drive and tap the pedal a lil and itll go away. You need a vaccum pump with gauge. Pull your fast Idle Thermo Valve and measure the vaccum there. Pull the vaccum advance off the distributor and see if idle responds correctly to applied vaccum. Above all, check for vaccum leaks. Remember, that air filter holder has pressed metal at the bottom and can, over time, rub through some of the vaccum lines that are beneath it. Link to comment Share on other sites More sharing options...
Turtlehead Posted April 2, 2009 Share Posted April 2, 2009 On top of what James said, when it happens try using your foot to lift UP on the gas pedal. If you notice a drastic difference then you may have a sticking throtle cable. Link to comment Share on other sites More sharing options...
94typersol Posted April 14, 2009 Share Posted April 14, 2009 or maybe because he took off his intake mani and took a dremel to it and hacked off chucks of metal. oh and he put it back on with half the gasket. he called it a port match job. Link to comment Share on other sites More sharing options...
dkzayne Posted April 16, 2009 Share Posted April 16, 2009 im not sure if this would help but if u have a throttle position sensor check that out cause i have a ford windstar and it went out and caused the same problems so try checkin that and no one on this post mentioned it so it either dont have one or they over looked it....hope this helps Link to comment Share on other sites More sharing options...
davidangelina06 Posted April 25, 2009 Share Posted April 25, 2009 my 91 accord lx has this weird and yet ever annoying problem when i first start the car it goes to 3k and doesnt want to come down i tried everything IACV, FTIV, reseting the ecu unplugging the IACV ajusting the idle screw everything the book says i have done but it doesnt go down the only time i can see results is if i unplug the IACV and leave it unplugged it dropes to 2k and surges to 2.2k to 1.8k never ever goes down to the recommended 700-800 idle rpms never try disconnecting your tps sensor and then starting you car, the sensor could be bad or the plug could be bad...give this a shot Link to comment Share on other sites More sharing options...
