04civic407 Posted March 24, 2009 Share Posted March 24, 2009 i have a 2004 civic dx. my suspension is knocking really badly. it only does it when im not hitting the gas or brakes. it would do it any any speed and its a stock suspension. i cant figure out whats doing it. can anybody help?? Link to comment Share on other sites More sharing options...
wannaBstuntin Posted March 24, 2009 Share Posted March 24, 2009 What makes you think its the suspension? Link to comment Share on other sites More sharing options...
04civic407 Posted March 24, 2009 Author Share Posted March 24, 2009 What makes you think its the suspension? your right i could be wrong. it seems to be coming from the suspension. what do you think could be causing this? Link to comment Share on other sites More sharing options...
Humphries Posted April 3, 2009 Share Posted April 3, 2009 tighten all bolts. my dads rear shock wasnt torqued to spec and it would knock a little bit until he finally torqued it down to 80 Ft/lbs. Link to comment Share on other sites More sharing options...
ToTriggerHappy Posted April 11, 2009 Share Posted April 11, 2009 i have a 2004 civic dx. my suspension is knocking really badly. it only does it when im not hitting the gas or brakes. it would do it any any speed and its a stock suspension. i cant figure out whats doing it. can anybody help?? Try your strut mounts. my friend has a svt focus and he had the same problem. it is usually the bushings that rot out on the strut mount. It shouldn't be expensive like $80 each... Link to comment Share on other sites More sharing options...
Xeryon Posted April 11, 2009 Share Posted April 11, 2009 Try your strut mounts. my friend has a svt focus and he had the same problem. it is usually the bushings that rot out on the strut mount. It shouldn't be expensive like $80 each... Sorry, pos focus is not comparable to a civic. Bushings do not rot away after only 5 years. Like the others have said, one of your suspension bolts probably backed itself out a turn or two. I experienced a similar problem with my rear control arms until I used some loc-tite on them. If you have some tools and time sit down and retighten anything you can reach in the area the sound seems to be coming from. If you are not the do-it-yourself kind of person cruise it on over to the local suspension fix-it place and let them take a look. Link to comment Share on other sites More sharing options...
