JoeX-97SE Posted March 24, 2009 Share Posted March 24, 2009 Hi, new to the forum. I just recently purchased a 97 Honda Accord SE. The powersteering pump was replaced. The powersteering seems to work fine, parking is not an issue. However while driving the car, the steering wheel does not return to center. If you are on the highway and slightly turn right, the car will continue in that path even if you let go of the wheel. Same for turning slighlty left. Also do all 97 Accords have speed-sensitive steering? Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Velocifero Posted March 24, 2009 Share Posted March 24, 2009 Inspect your ball joints, they probably need replacing. Mine did the same as you, until I replaced them all and the wheel swung right around, smooth as ever. Link to comment Share on other sites More sharing options...
