Screamer Posted May 8, 2009 Share Posted May 8, 2009 Sup guys, I'm new to this group and new to modifying cars. I have a 1998 coupe D16Y8 engine stock, and I want to know how to get at least 150 - 175hp. Right now I believe I'm running 127hp and 108 whp, but I wanna get it up there. A couple of people tells me an intercooler would work great. But I wanna know a just a couple things if noones to busy. How much potential horsepower would an aftermarket: Header? Exhaust Manifold? Intercooler? Catback? Camshafts? And if there is anything else I could do to boost my hp. Thanks guys! Link to comment Share on other sites More sharing options...
CleanGSR Posted May 8, 2009 Share Posted May 8, 2009 Sup guys, I'm new to this group and new to modifying cars. I have a 1998 coupe D16Y8 engine stock, and I want to know how to get at least 150 - 175hp. Right now I believe I'm running 127hp and 108 whp, but I wanna get it up there. A couple of people tells me an intercooler would work great. But I wanna know a just a couple things if noones to busy. How much potential horsepower would an aftermarket: Header? Exhaust Manifold? Intercooler? Catback? Camshafts? And if there is anything else I could do to boost my hp. Thanks guys! Um.....this list will get you there for about the same amount as money as the stuff above....and you don't do an intercooler with a header. Civic HF manifold 14b adapter plate Factory 14b DSM turbo DSM 450cc injectors' and resistor box Godspeed Intercooler and piping Used Greddy/HKS/etc...BOV Oil feed and return lines 2.5-3" downpipe A good tune and around 10psi on that setup that should get you close to the 200whp mark. Chipped ECU dyno tuned on Crome Link to comment Share on other sites More sharing options...
alex37211 Posted May 8, 2009 Share Posted May 8, 2009 I'm with Nate on this one. That's pretty much the exact parts list that I've assembled for my d16z6 plus a walboro pump, aem uego, and s300. Link to comment Share on other sites More sharing options...
jerrodh Posted May 8, 2009 Share Posted May 8, 2009 Listen to nate, and as for the intercooler thats a turbo part as a header/intake is when your running an NA setup. Link to comment Share on other sites More sharing options...
Screamer Posted May 14, 2009 Author Share Posted May 14, 2009 Um.....this list will get you there for about the same amount as money as the stuff above....and you don't do an intercooler with a header. Civic HF manifold 14b adapter plate Factory 14b DSM turbo DSM 450cc injectors' and resistor box Godspeed Intercooler and piping Used Greddy/HKS/etc...BOV Oil feed and return lines 2.5-3" downpipe A good tune and around 10psi on that setup that should get you close to the 200whp mark. Chipped ECU dyno tuned on Crome sweeet! thanks guys!! =) Link to comment Share on other sites More sharing options...
