dkzayne Posted May 25, 2009 Share Posted May 25, 2009 a buddy of mine was tlkin to me about tuning the timing and how we could make the car run leaner and get more horsepower he said around 40 more to be exact does anybody know how this works and how you truely go about doin it also what are the ups and downs of doin this??? Link to comment Share on other sites More sharing options...
Hatch92 Posted May 25, 2009 Share Posted May 25, 2009 you can advance timing on a stock motor to get a little more power but your not making it lean Link to comment Share on other sites More sharing options...
dkzayne Posted May 25, 2009 Author Share Posted May 25, 2009 ok well how would you about doing this??? would youi just slip the timimg belt off and move the cams??? Link to comment Share on other sites More sharing options...
Kastigir Posted May 25, 2009 Share Posted May 25, 2009 You change ignition timing...not camshaft timing. You'll also have to run higher octane gas because of the timing advance. Honestly, it's a minimal gain, so up to you if the $.20/gallon more is worth it. You can also lean out the A/F ratio to make more power, but that also creates the potential to blow the motor. Link to comment Share on other sites More sharing options...
Hatch92 Posted May 25, 2009 Share Posted May 25, 2009 ^agreed Link to comment Share on other sites More sharing options...
CleanGSR Posted May 25, 2009 Share Posted May 25, 2009 You'll never make as much hp as your friend said. You might gain 2-3hp if you're lucky. Advancing your timing can also increase your gas mileage if you keep your foot out of it. Link to comment Share on other sites More sharing options...
dkzayne Posted May 26, 2009 Author Share Posted May 26, 2009 well the guy thats helpin me has a nissan sentra ser spec v and i drove his car before and after he did the same and run runs way better and seems to have a considerable amount of more pick up could it be just his motor??? Link to comment Share on other sites More sharing options...
cranny Posted May 26, 2009 Share Posted May 26, 2009 first - ignition timing is set the way it is for many reasons. physics mainly and the way the engine was designed. mainly combustion chamber design and compression ratio. im not gonna get too complicated here. set it to stock and leave it. second - dont listen to guys with nissan sentras , lol. Link to comment Share on other sites More sharing options...
