Xavier Posted May 28, 2009 Share Posted May 28, 2009 So i have a d16y8 and am planning on boosting my ej8 civic,,,, im going to rebuild my engine with the vitara pistons, eagle rods, arp bolts, and installing a t3/t4 garett turbo-57 trim, etc..... but i want to run it on 91 octane...round how much power will a be putting out????? and how reliable would it be with a good tune??? If anyone has done this setup please let me know!!! Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 28, 2009 Share Posted May 28, 2009 So i have a d16y8 and am planning on boosting my ej8 civic,,,, im going to rebuild my engine with the vitara pistons, eagle rods, arp bolts, and installing a t3/t4 garett turbo-57 trim, etc..... but i want to run it on 91 octane...round how much power will a be putting out? ??? ? and how reliable would it be with a good tune??? If anyone has done this setup please let me know!!! with the reinforcement your doing with the rods, bolts, and pistons it should be great if you get a good tune. the 91 octane may present a problem if you plan on running a good bit of boost. so im not sure on the power level youll end up with, its all in the tune Link to comment Share on other sites More sharing options...
Pballer2005 Posted May 30, 2009 Share Posted May 30, 2009 vitara's are going to kill your compression which should easily allow you to run pump gas on a safe tune. boost and what gas to use are all based on what you tune it for. Link to comment Share on other sites More sharing options...
Xavier Posted June 1, 2009 Author Share Posted June 1, 2009 thanks alot that really helps!!!well hope its what i expect!!! Link to comment Share on other sites More sharing options...
