Beholder Posted August 30, 2009 Share Posted August 30, 2009 I've got a 2008 Accord EX-L i-4 5MT and for the past few months i've noticed that sometimes (not all the time) when shifting from 2nd to 3rd i get a clunking when i lift off the clutch. I'm trying to figure out how i can consistently reproduce this issue as it doesnt always happen. Does anyone else have thsi issue. I've got 10% oil life left so it'll be going into the dealer for service soon but my biggest fear is them not being able to reproduce the issue so was hoping someone else could shed some light on this for me. A side note - i've always had issues with 3rd gear in this car, like it doesn't seem to go as smoothly into 3rd gear as it does for any other gear. When i first got the car i found i'd lift the clutch before it was in 3rd gear due to me not being used to it and it woudl pop out. Now i got used to it so it's not a problem but now its just the inconsistent clunking. any ideas? thoughts? Thanks, Andy Link to comment Share on other sites More sharing options...
airjordan223 Posted August 30, 2009 Share Posted August 30, 2009 how many miles are on the car Link to comment Share on other sites More sharing options...
Beholder Posted September 2, 2009 Author Share Posted September 2, 2009 how many miles are on the car 28,000 Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 3, 2009 Share Posted September 3, 2009 you may have damaged the syncro or actual gear in third gear from the repeated grinding Link to comment Share on other sites More sharing options...
xxhrdcr4lifexx Posted September 3, 2009 Share Posted September 3, 2009 its as allmost as you have a tooth missing from 3rd so its slipping sometimes, could be a through out bearing, could be a couple dif things. wrong with it, but thats weird only 28k on it, could be a poorly built trans, might just take it to a trans mechanic or a dealership so they can crack the case and look inside it. Link to comment Share on other sites More sharing options...
RichB in AZ Posted September 7, 2009 Share Posted September 7, 2009 How does the linkage work on the tranmission? Is it rods or cables (I don't know, just tossing out an idea) Link to comment Share on other sites More sharing options...
