zoltron30 Posted August 31, 2009 Share Posted August 31, 2009 i have a 2001 4cyclinder honda accord and it seems that the AC has stopped working on the first 2 levels. it seems to operate fine on levels 3 and 4 but not 1 and 2. honda mentioned that it was the blower motor and they want close to 200.00 to fix/replace.... any suggestions Link to comment Share on other sites More sharing options...
James Matteu Posted August 31, 2009 Share Posted August 31, 2009 If the problem was the blower motor, you would loose all speeds; intermittently or permenently. Since the problem you have is the Blower Resistor, you loose one or more speeds. Replace your Blower Resistor. Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted August 31, 2009 Share Posted August 31, 2009 no a/c FTW lol Link to comment Share on other sites More sharing options...
alex37211 Posted August 31, 2009 Share Posted August 31, 2009 could also be the switch. I agree the blower is probably good. Link to comment Share on other sites More sharing options...
James Matteu Posted August 31, 2009 Share Posted August 31, 2009 I agree, check both the switch and the resistor. Link to comment Share on other sites More sharing options...
zoltron30 Posted September 1, 2009 Author Share Posted September 1, 2009 If the problem was the blower motor, you would loose all speeds; intermittently or permenently. Since the problem you have is the Blower Resistor, you loose one or more speeds. Replace your Blower Resistor. hmm yeah my local mechanic said the same thing... i'm going to give him a call tomorrow..... Link to comment Share on other sites More sharing options...
