jtwellner Posted September 16, 2009 Share Posted September 16, 2009 We have an 1993 Acura Integra behind my dads shop with a over heated engine. I wanted to know if the rear disk brakes on it would fit my 1989 Honda CRX Hatchback HF to replace the drum brakes which get to hot when racing. Link to comment Share on other sites More sharing options...
airjordan223 Posted September 16, 2009 Share Posted September 16, 2009 i believe they will. i think you might have to do something with the e-brake cable though Link to comment Share on other sites More sharing options...
jtwellner Posted September 17, 2009 Author Share Posted September 17, 2009 i believe they will. i think you might have to do something with the e-brake cable though Ok, thanks for the info. I just didn't want to tear into it and waste my time finding it wont work. But the Acura has a e-brake with a cable...shouldn't it work? Link to comment Share on other sites More sharing options...
airjordan223 Posted September 18, 2009 Share Posted September 18, 2009 different lengths Link to comment Share on other sites More sharing options...
Li5t3d Posted September 18, 2009 Share Posted September 18, 2009 yes you can swap it over i had a 89 civic hatch and a 93 teggy that was wrecked i pulled the motor from it to swap into the hatch an swapped over the disc to the hatch couldnt tell you how to hook them up tho cause in the process of running the brake line a guy made an offer on the civic and i let it go :( Link to comment Share on other sites More sharing options...
Joe W Posted September 19, 2009 Share Posted September 19, 2009 Yep they will fit, ebrake cables are long, but can be tucked neatly w/out interference. Link to comment Share on other sites More sharing options...
