Malaka1689 Posted November 24, 2009 Share Posted November 24, 2009 Hey, Im new to the forums and am seeking advice on my 99 Accord v6. Sometimes the car will not start. It will keep making the cranking noise until i let go of the key. I checked the spark plugs and wires and everything is ok. Occasionally ill hold the gas down when starting because it seems to make the car start more frequently. Any advice on how to go about this problem? Link to comment Share on other sites More sharing options...
Velocifero Posted November 24, 2009 Share Posted November 24, 2009 Hey, Im new to the forums and am seeking advice on my 99 Accord v6. Sometimes the car will not start. It will keep making the cranking noise until i let go of the key. I checked the spark plugs and wires and everything is ok. Occasionally ill hold the gas down when starting because it seems to make the car start more frequently. Any advice on how to go about this problem? Weird, that usually only works on carb'd cars. Is your battery ok? Check the voltage on it with a multimeter. Link to comment Share on other sites More sharing options...
JesseCuster Posted November 24, 2009 Share Posted November 24, 2009 IMO, you should check out your fuel pump if thats all good, should look at your main relay. these are just 2 suggestions, there are mroe Link to comment Share on other sites More sharing options...
Velocifero Posted November 25, 2009 Share Posted November 25, 2009 When you turn the key to the "II" (just prior to cranking), listen for the fuel pump priming. If you fail to hear this, most likely it's your main relay. Make sure everything's quiet so you hear it well. Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted November 25, 2009 Share Posted November 25, 2009 WRONG!! check your dizzy (distributor) my rotor, cap, and coil went bad when i was in ft knox and it did the same thing youre talking about.. the rotor was $18 and the cap was $12 i think and the coil was like $70 and that fixed everything.. even if it isnt your cap and rotor, it wont kill your pocket.. the coil is the only expensive thing.. Link to comment Share on other sites More sharing options...
Velocifero Posted November 25, 2009 Share Posted November 25, 2009 WRONG!! check your dizzy (distributor) my rotor, cap, and coil went bad when i was in ft knox and it did the same thing youre talking about.. the rotor was $18 and the cap was $12 i think and the coil was like $70 and that fixed everything.. even if it isnt your cap and rotor, it wont kill your pocket.. the coil is the only expensive thing.. Same symptoms as a main relay ya douche. And costs almost the same. It's less than $100. Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted November 26, 2009 Share Posted November 26, 2009 just chekc teh daumn dizzey.. bet thatz teh problum Link to comment Share on other sites More sharing options...
