hiemsnox Posted January 16, 2010 Share Posted January 16, 2010 So my "new to me" 94 del sol, the vtec isnt working, i tried swapping the solenoid with the one from my 95, which i know works... didnt fix the problem, so im kinda lost as to what to check next. and the only thing i noticed that was different from the two care was that the 95 plug fit with the bung of the 94... but the 94 plug didnt fit in the 95 bung. also on the 94(the one that isnt working) under where the soleniod fits there is this button like thing with a small hole in it.. its sticking out a little bit and can be pressed in but comes right back out... but on the 95(the one that is working) that little button things just stays down... Please help and thank you Link to comment Share on other sites More sharing options...
Xeryon Posted January 17, 2010 Share Posted January 17, 2010 Since this is an unknown car, do you know for certain it has the right ecu? any cels? Link to comment Share on other sites More sharing options...
hiemsnox Posted January 17, 2010 Author Share Posted January 17, 2010 Since this is an unknown car, do you know for certain it has the right ecu? any cels? unknown car??? i know what it is... they are both del sols.... and yes it has the right ecu and no there is no check engine lights. Link to comment Share on other sites More sharing options...
DelSolSweetie Posted January 17, 2010 Share Posted January 17, 2010 1) Make sure your driving it.. it won’t crossover in neutral 2) Make sure oil level and oil pressure are good 3) Make sure car is at normal operating temperature 4) Make sure there is no check engine light 5) Make sure your speedo is working 5) Make sure wires/plugs are tight or wired correctly 6) Make sure vtec solenoid is clean 7) Make sure you have a vtec enabled ecu 8 ) Make sure you actually have a vtec engine If you can not HEAR it clearly that does not mean it is not working. Get a test light and check it. Link to comment Share on other sites More sharing options...
Xeryon Posted January 17, 2010 Share Posted January 17, 2010 unknown car??? i know what it is... they are both del sols.... and yes it has the right ecu and no there is no check engine lights. Exactly what you said it was: the new to you car. You haven't owned it long enough to know everything about it yet. Link to comment Share on other sites More sharing options...
