Mille-16i Posted January 20, 2010 Share Posted January 20, 2010 I have a 94 CD7 EX unfortunantly with an auto tranny. It has recently started acting up with no warning about 3 weeks ago it started hesitating to go into drive and if you got on it at all it would slip real bad until you let off and then it would drive fine. It did this for 2 weeks then one night it just refused to go into drive. I am trying to see what issue these trannys have are they normally good trannys or not really I know the 6th gen accords have crappy a/t's. It should be noted that I drive my car hard it sees redline and speed regularly and it has 240k on it. Link to comment Share on other sites More sharing options...
James Matteu Posted January 22, 2010 Share Posted January 22, 2010 Check your fluid level, all you have described could be attributed to low ATF volume which results in low ATF pressure and poor performance. If you find the level is low, verify all ATF line connections going into and out of the AT aren't leaking; this includes making sure ATF is not mixed with your coolant. Let us know what you find. Link to comment Share on other sites More sharing options...
Mille-16i Posted January 26, 2010 Author Share Posted January 26, 2010 Checked fluid again to double check it is full when hot and the tranny will pull ok (never leaves second gear) till it gets hot then it is done and the fluid smell burnt ie trannys is toast something went bad inside it. My main reason for this post was really to hear of the normal problems these autos give is mine the norm or exception. Link to comment Share on other sites More sharing options...
James Matteu Posted January 28, 2010 Share Posted January 28, 2010 With so many factors involved, it is hard to say what is normal and what is not. To try and put an answer to your question: yes, it is not unheard of for an Accord automatic transmission with 204,000 miles to fail. Link to comment Share on other sites More sharing options...
