hbgrealtor Posted January 21, 2010 Share Posted January 21, 2010 Hello. I have a 1996 Del Sol. 196000 miles. Stock. One day it wouldn't, I checked for spark. There was none. Replaced the distributor and the rotor and cap. It started right up. An hour later it wouldn't start. Got another distributor. Started right up. an hour later it wouln't start. The next day I was checking for spark and it had spark. Started up. A couple hours later it wouldn't start. Swapped out the ECM. Nothing. Does anybody know what is wrong with this car. Thanks for your help. Link to comment Share on other sites More sharing options...
DelSolSweetie Posted January 21, 2010 Share Posted January 21, 2010 check the ground check spark plugs Link to comment Share on other sites More sharing options...
tallhamer88 Posted January 21, 2010 Share Posted January 21, 2010 sounds like the same issue i had with my battery terminals going bad. Link to comment Share on other sites More sharing options...
Orca89 Posted January 21, 2010 Share Posted January 21, 2010 I'd bet it's the engine ground... Just get some fine grit sandpaper and make the contacts nice and shiny. If that doesn't fix it... Probably needs a new coil Link to comment Share on other sites More sharing options...
