9xnine Posted February 3, 2010 Share Posted February 3, 2010 When I apply the brakes my door ajar light/chime comes on (91 CRX DX). Both door pins test ok. Any ideas? Thanks Link to comment Share on other sites More sharing options...
R'90//CRX-DX Posted March 31, 2010 Share Posted March 31, 2010 I have the same problem... Check the door from your trunk... In my crx the trunk door can close, but the lock switch is not working. Wich means if I open the door it wont close again, unless I manually move the lock into place. At the moment its closed but the door ajar turns on every time I hit the brakes or a run into a pothole. It wouldnt hurt giving it a quick inspection!!! Link to comment Share on other sites More sharing options...
