tonkkids Posted June 12, 2010 Share Posted June 12, 2010 My 1994 LX started spitting & sputtering through the exhaust. It seems as though it is starving for gas. Here is what I have checked and replaced: Replaced: Fuel Filter Coil Distributor Main Relay Checked the Fuel Pump Fuel pressure good Ran STP injector cleaner through the tank Ran SeaFoam through the vacuum lines Car does fine when cool and when coasting When it is up to operating temp and when you go uphill and when you give it some gas, it acts like it is starving. Just spits and hesitates. Dont want to go. Any help is greatly appreciated... Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 12, 2010 Share Posted June 12, 2010 My 1994 LX started spitting & sputtering through the exhaust. It seems as though it is starving for gas. Here is what I have checked and replaced: Replaced: Fuel Filter Coil Distributor Main Relay Checked the Fuel Pump Fuel pressure good Ran STP injector cleaner through the tank Ran SeaFoam through the vacuum lines Car does fine when cool and when coasting When it is up to operating temp and when you go uphill and when you give it some gas, it acts like it is starving. Just spits and hesitates. Dont want to go. Any help is greatly appreciated... Go to exhaust shop and have them test muffler and cat. If exhaust is stock, or muffler is really old, it could be falling apart internally and restricting flow. Same with cat. Link to comment Share on other sites More sharing options...
tonkkids Posted June 12, 2010 Author Share Posted June 12, 2010 had the exhaust replaced a couple of months ago. i do need to check the catalyc converter though...thanks for the idea Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 12, 2010 Share Posted June 12, 2010 had the exhaust replaced a couple of months ago. i do need to check the catalyc converter though...thanks for the idea Hit it and see if you hear a bunch of crap inside of it. Link to comment Share on other sites More sharing options...
misterspock07 Posted June 14, 2010 Share Posted June 14, 2010 i would not replace the cat. lots of money for that ha... just cut it and hollow it out and it will run just as good if not better as with it bein new. also check ur fireing out i have and 85 and it was doing the same i hollowed the cat thinking it was that but it was actually my wires were bad and had cracks in them by the block and was sparking on the top of my header u can tell if it is doing that by starting it up in the dark with no lights on around the car.... just some friendly input.. Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 14, 2010 Share Posted June 14, 2010 i would not replace the cat. lots of money for that ha... just cut it and hollow it out and it will run just as good if not better as with it bein new. also check ur fireing out i have and 85 and it was doing the same i hollowed the cat thinking it was that but it was actually my wires were bad and had cracks in them by the block and was sparking on the top of my header u can tell if it is doing that by starting it up in the dark with no lights on around the car.... just some friendly input.. BS!! Cat will run you $50.00!! I can send you a link to a direct seller of Magnaflow hi-flow cat. Link to comment Share on other sites More sharing options...
