Ebar082 Posted July 12, 2010 Share Posted July 12, 2010 Hi all I have recently bought a 1993 Honda Accord Si-R, it is the same shape as the 1994 - 1997 models, and has the same air conditioning unit, which is separate from the stereo and center console, and situated right above the clock. Unfortunately the lights don't work, the buttons dont respond, and there is absolutely no heating or cooling or any air flow whatsoever, along with this the rear window defroster does not work. Essentially the whole component seems dead. The last owner said the unit worked intermittantly until one day it stopped working altogether. I need to get this fixed because its getting damn cold here now, and having to drive in a freezing car is getting more and more painful each day. If you could throw some ideas out there that would be awesome. Link to comment Share on other sites More sharing options...
Velocifero Posted July 12, 2010 Share Posted July 12, 2010 Freezing? You must be in on the Southern Hemisphere, Australia I'm guessing. I would check all of the fuses first. Then pop that whole panel back from the dash and make sure everything is plugged in. Link to comment Share on other sites More sharing options...
Ebar082 Posted July 12, 2010 Author Share Posted July 12, 2010 Thanks mate Am i correct in saying there is only one fuse box which is on the left hand side (looking front on) just beside the firewall? Found this sweet website you might be interested in. http://www.dhost.info/accordinfo/ Link to comment Share on other sites More sharing options...
