Trae%eh6 Posted December 26, 2010 Share Posted December 26, 2010 ok been a while since i got on. i just want to check on something b4 i spend this much money. the other day my d took a sh!t on me, so now im thinking of doing a itr swap. so here is my question? if i go with a 96-97 spec itr. will it be plug and play with a stock d16y8 wiring harness. i know how to do everything eles for the swap i just want this part to be bug and play. also i will be buying the motor from hmotorsonline Link to comment Share on other sites More sharing options...
Raley Posted December 26, 2010 Share Posted December 26, 2010 You have a y8 in a 94 sol? Link to comment Share on other sites More sharing options...
Trae%eh6 Posted December 26, 2010 Author Share Posted December 26, 2010 hell no when i made my name on here i had a 94 sol i still have pics of it up but now i have a 97 ex civic. Link to comment Share on other sites More sharing options...
Raley Posted December 26, 2010 Share Posted December 26, 2010 I dunno much about ek's but id guess youll have to remove some wire loom. Only thing i think youll be missing is the knock sensor stuff. Link to comment Share on other sites More sharing options...
Trae%eh6 Posted December 26, 2010 Author Share Posted December 26, 2010 I dunno much about ek's but id guess youll have to remove some wire loom. Only thing i think youll be missing is the knock sensor stuff. the knock sensor i dont care i want to run a p28 with a chipped on s300. but i want to know is will it be plug and play as far the dizzy injectors and alternater. Link to comment Share on other sites More sharing options...
eg4door Posted December 26, 2010 Share Posted December 26, 2010 i dont see why you would a problem, both car years are obd-2, you might have to stretch the harness out, thats what i had to do when i swapped in a dohc vtec. and to run a p28 is the best, you will just need the step down harness. Link to comment Share on other sites More sharing options...
Raley Posted December 26, 2010 Share Posted December 26, 2010 97 is 97... to run a p28 youll need a conversion harness. Link to comment Share on other sites More sharing options...
Trae%eh6 Posted December 26, 2010 Author Share Posted December 26, 2010 yea i know you have to have a jumper for the ecu i just want to make sure that the Dizzy alternator injector are all going to match up other than that i know how to do the rest Link to comment Share on other sites More sharing options...
Raley Posted December 26, 2010 Share Posted December 26, 2010 97 is 97... if the wires are long enough is a different story. They will all plug in IF they are long enough. Link to comment Share on other sites More sharing options...
Trae%eh6 Posted December 26, 2010 Author Share Posted December 26, 2010 if they have to i will just add wire. i just dont want to spend most of my money on this and then something come up you know what im saying. but thank you Link to comment Share on other sites More sharing options...
