Wi Dave Posted February 19, 2011 Share Posted February 19, 2011 I have a 93 Del Sol Auto with two issues 1) The fuel pump takes up to 10 minutes to kick on when the car is wet. Dry out the fuel pump turns on right away and the car starts right up and run great. Once the car starts it run great. 2)Vibration when slowly accelerating from say 65 up. Below 65 the car is smooth. Had the tied rods and boots replaced. Seems a little better but did not effect the vibration above 65. I am leaning towards transmission as the tach is all over the place but has been since 75K Car does not slip accelerates hard. As soon as I let off the gas the vibration goes away. The car is lowered but did not have issue until recently. Has 126,000 miles Link to comment Share on other sites More sharing options...
kdozier Posted February 19, 2011 Share Posted February 19, 2011 I would venture to say your first problem (fuel pump) isn't actually the pump itself. But the fuel pump relay instead. You can test the relay to see if it's any good. As for your second problem: Do you think your tires need to be balanced? It could be as simple as that.... you never know.... Link to comment Share on other sites More sharing options...
Wi Dave Posted February 19, 2011 Author Share Posted February 19, 2011 I changed the tires/rims and re-soldered all the connections on the main relay. Is there an additional fuel pump relay or just the main relay? Tried to upload photo but could not figure out how to make it small enough? Link to comment Share on other sites More sharing options...
Wi Dave Posted February 20, 2011 Author Share Posted February 20, 2011 Check to see if you've got a buckled wheel... My sol's steering wheel was vibrating when going about 60+, thought it was the wheel that needed balancing, found out one of the front wheels was pretty damn buckled! But did your vibration go away the second you let off the gas? I changed the tires and rims today and drove it but the road was so rough in Wisconsin I could not tell if there was a difference I may have to wait till I go back to work there is a smooth stretch on the way there. Link to comment Share on other sites More sharing options...
kdozier Posted February 20, 2011 Share Posted February 20, 2011 There should be an online tech manual for the Del Sol. There is a fuel section which explains how the fuel pump works. I tried to attach the PDF but was unsuccessful. Basically what it said was the fuel pump relay consists of 2 relays. The first one turns on the ECM and everything except the pump itself. When the first relay turns on makes the second relay come on and it energizes the fuel pump. Relays tend to stick and they're much cheaper than replacing the fuel pump so I'd look into replacing the relay... Link to comment Share on other sites More sharing options...
Wi Dave Posted February 21, 2011 Author Share Posted February 21, 2011 I have a 93 Del Sol Auto with two issues 1) The fuel pump takes up to 10 minutes to kick on when the car is wet. Dry out the fuel pump turns on right away and the car starts right up and run great. Once the car starts it run great. 2)Vibration when slowly accelerating from say 65 up. Below 65 the car is smooth. Had the tied rods and boots replaced. Seems a little better but did not effect the vibration above 65. I am leaning towards transmission as the tach is all over the place but has been since 75K Car does not slip accelerates hard. As soon as I let off the gas the vibration goes away. The car is lowered but did not have issue until recently. Has 126,000 miles My link link to pics of my del sol Link to comment Share on other sites More sharing options...
Drop Shock Posted February 21, 2011 Share Posted February 21, 2011 My link link to pics of my del sol woowww dude thats a really clean lookin sol my man. besides those tailights it looks really good. Link to comment Share on other sites More sharing options...
