CJB!!! Posted February 21, 2011 Share Posted February 21, 2011 I had a d15 that was burning oil like crazy so I fully cleaned and rebuilt my d16 and swapped it in with a new clutch bearing and everything. Now it stumbles on acceleration and the stumbling doesn't go away even at cruise. You can even hear the stumbling at idle with slight fluctuation of the rpm needle. It ran fine before the swap just smoke coming out the exhaust. Any questions or ideas? Link to comment Share on other sites More sharing options...
Raley Posted February 21, 2011 Share Posted February 21, 2011 Timing or lack of fuel... id guess timing. Link to comment Share on other sites More sharing options...
CJB!!! Posted February 21, 2011 Author Share Posted February 21, 2011 That's what I was thinking. I'll move the timing belt one tooth and see if I can set it with my timing light. The cam and crank line up at tdc but with the timing light I can't set 16 degrees btdc without slamming the distributor all the way to one side. Its weird Link to comment Share on other sites More sharing options...
Raley Posted February 21, 2011 Share Posted February 21, 2011 Belt is streching or your tension is outta wack. Link to comment Share on other sites More sharing options...
CJB!!! Posted February 21, 2011 Author Share Posted February 21, 2011 Could a restricted cat cause the stumbling? I was burning oil for at least two months.. Link to comment Share on other sites More sharing options...
Raley Posted February 22, 2011 Share Posted February 22, 2011 Possible but would stumble more at higher rpm. Link to comment Share on other sites More sharing options...
CJB!!! Posted February 22, 2011 Author Share Posted February 22, 2011 There was one other thing that was irregular, I can hear a tick in the distributor like an extra spark. Its not consistent either, now I checked plugs, they are perfect and I looked at the wires and there is some corrosion on both ends of a few of them. Could this cause a miss like a stumble as well? Link to comment Share on other sites More sharing options...
CJB!!! Posted February 23, 2011 Author Share Posted February 23, 2011 My ckp is cracked but not broken. if your not familiar with hondas it is located in the distributor. Also it backfired on a test drive today Link to comment Share on other sites More sharing options...
