moosehunter Posted February 26, 2011 Share Posted February 26, 2011 i recently bought a 98 civic cx with a swapped b16a2 in it. When the swap was done the original cluster from the 2000 Si was installed as well. For some reason the check engine light does not work. Is this a common problem and what should i do to fix it? Im wondering if it was disabled on purpose or not? Link to comment Share on other sites More sharing options...
