flipout Posted July 22, 2011 Share Posted July 22, 2011 i have a 91 honda accord with a stock f22a1 motor in it. i just got a f22b1 vtec head from a 95 accord. im planning on swaping the heads soon but i need to kno if i need a jumper harness for the ecu since im putting an obd1 head on and will be running obd1 ecu, and my car is obd0. if i do need a jumper harness where can i get one. i also need to kno what type of ecu i should run to get the full potential of my engine. if someone can help me with this id appreciate it. thanks Link to comment Share on other sites More sharing options...
Raley Posted July 22, 2011 Share Posted July 22, 2011 Locash has hardess, so does chase bays/rywire. Full potential, aem... a chipped ecu would be fine too. What are your funds? Link to comment Share on other sites More sharing options...
flipout Posted July 22, 2011 Author Share Posted July 22, 2011 I don't rele have a limit to my funds. I've been slowly gathering all the parts I need over the last few months. I jus need a jumper harness and ecu before I have everything installed Link to comment Share on other sites More sharing options...
flipout Posted August 2, 2011 Author Share Posted August 2, 2011 IS THERE A WAY I CAN BYPASS A JUMPER HARNESS AND USE MY ORIGINAL WITH A VTEC CONTROLLER. OR WOULD IT BE EASIER TO SWAP THE HARNESS WITH ONE FROM A 94 VTEC F22? Link to comment Share on other sites More sharing options...
Raley Posted August 2, 2011 Share Posted August 2, 2011 IT WOULD BE MUCH MUCH MUCH EASIER TO READ IF YOU TYPED IN LOWER CASE!!!!!!! On that note, get the jumper harness its way easier. Link to comment Share on other sites More sharing options...
flipout Posted August 3, 2011 Author Share Posted August 3, 2011 lol my bad and thanks. Link to comment Share on other sites More sharing options...
