PatrykBojanowski Posted August 16, 2011 Share Posted August 16, 2011 Hey, so i got a little problem that I just dont really understand. Lets start off with the car, its a 1999 honda accord lx 3.0L vtec that i bought around a month ago. So far i had to replace the front wheel bearings and all of the brake pads, but now im puzzled of what is going on. The problem is that it cranks but doesnt start, but after a few tries and just chilling in the car for a few mins it starts right up. It has happened twice to me and both of the times were after it was parked in the sun for a few hours (if that has anything to do with it lol). Like i said, it has happened only two times and it usually starts right up with no problems at all. I was thinking that maybe the fuel filter might be getting clogged so i could replace that. Spark plugs might need to be replaced since there is around 113k on the car and i dont know when they were replaced, or maybe a loose ground wire? Let me know what you guys think, i really dont know where to start with this.. Link to comment Share on other sites More sharing options...
PatrykBojanowski Posted August 16, 2011 Author Share Posted August 16, 2011 i did some research and found out that it most likely is the fuel pump relay. seems that a lot of people are experiencing the same problems in hot weather and replacing the relay solved their problems. Link to comment Share on other sites More sharing options...
159569 Posted August 17, 2011 Share Posted August 17, 2011 レプリカ IWC腕時計 IWC腕時計 IWCのパイロットはクラシックウォッチ IWCアクアタイマー IWCのポルトガル語 IWCのパイロットはスピットファイアウォッチ IWCのIngenieur IWCのビッグパイロットはウォッチ IWCのパイロットはUTC腕時計 IWCのスペシャル IWCのポルトフィーノ IWCのダヴィンチ IWCのビンテージコレクション IWCのサブマリーナー IWC時計 IWCブランパン レプリカ IWC腕時計 IWC腕時計 IWCのパイロットはクラシックウォッチ IWCアクアタイマー IWCのポルトガル語 IWCのパイロットはスピットファイアウォッチ IWCのIngenieur IWCのビッグパイロットはウォッチ IWCのパイロットはUTC腕時計 IWCのスペシャル IWCのポルトフィーノ IWCのダヴィンチ IWCのビンテージコレクション IWCのサブマリーナー IWC時計 IWCブランパン Link to comment Share on other sites More sharing options...
