JigMcGalliger Posted August 17, 2011 Share Posted August 17, 2011 My 1994 Accord non-Vtec 2.2 LX starts and stop immediately, I have been troubleshooting some issues and have already ruled out some issues. New parts already in car (within the past year) Alternator Starter Distributor Spark plugs Spark cables Fuel filter Valve cover and plug gaskets The OBD1 codes 3 (MAP sensor) and 15 (Ignition output system), I put in a new MAP sensor and reset the the codes and now I only have the code 15, good news? Not sure if the car needs to run to get more codes, still same problem of starting and only lasting a few revs. As for other issues the ICM comes new with the distributor. Checked all the ignition and starter fuses. The spark plugs are firing fine as the engine was in rotation for a second, which leads me to believe the fuel is cutting out, but that doesn't make sense for the code I'm getting. Any help is appreciated. Link to comment Share on other sites More sharing options...
