zoltron30 Posted September 10, 2011 Share Posted September 10, 2011 2001 honda accord and the check engine light is on. occured shortly after i put 87 (canada) gas in my tank. mechanic says its the evap, advised to drive until the gas tank empties then try premium gas. any thoughts? i had the car since 2006 and always used basic gas. guess its worth a try.... but if it is the evap whats the cost of repair? thanks Link to comment Share on other sites More sharing options...
Raley Posted September 10, 2011 Share Posted September 10, 2011 you will wanna check on your local area for a cost... and it depends on what part of the evap... Link to comment Share on other sites More sharing options...
zoltron30 Posted September 11, 2011 Author Share Posted September 11, 2011 is the evap an actual hose in the car or is it something larger? i dont think putting a higher grade of gas will do anything.... Link to comment Share on other sites More sharing options...
Raley Posted September 12, 2011 Share Posted September 12, 2011 The evap system is quite large, we would need the code to narrow it down more. Link to comment Share on other sites More sharing options...
