lmhager_09 Posted October 13, 2011 Share Posted October 13, 2011 I have a 2000 honda accord EX, my "main't req'd" light came on two weeks ago, we took it too advanced auto they ran a computer diagnostics test on it and the P0700 code and the P1739 code came up. I replaced the 3rd clutch trans. fluid pressure swtich yesterday (which they said is why the P1739 code came up) and my "main't req'd" light was still on....went back to advanced auto they hooked it up to the computer again and this time it read "NO CODES"...we went ahead and hit erase anyways. disconnected it and my light is still on...what do i do know?...replace the TCM?...or the solenoid pack?....any help or suggestions would be GREAT! Link to comment Share on other sites More sharing options...
Xeryon Posted October 13, 2011 Share Posted October 13, 2011 Maintenance required just means your car is due for an oil change. Stolen from a random place on the net cause I was too lazy to type it out. Honda Accord 98-02: Resetting Maintenance Required Indicator 1) Turn they key to the II position 2) Turn the key to the off position, and push and hold in the odometer reset button 3) Turn they key back to the II position, while still holding the button. 4) After about 10-15 seconds, the light should go off. Link to comment Share on other sites More sharing options...
