willyj Posted October 20, 2011 Share Posted October 20, 2011 96 v-6 accord #4 cylinder is missing. I have plenty of spark, Cheched the fuel injector its working fine but when i pull the plug wire off it doesnt change the way it runs. Going crazy please help Link to comment Share on other sites More sharing options...
Raley Posted October 20, 2011 Share Posted October 20, 2011 Smoking at all? Link to comment Share on other sites More sharing options...
willyj Posted October 20, 2011 Author Share Posted October 20, 2011 No smoke Link to comment Share on other sites More sharing options...
Raley Posted October 20, 2011 Share Posted October 20, 2011 Check compression Link to comment Share on other sites More sharing options...
willyj Posted October 20, 2011 Author Share Posted October 20, 2011 Good comp. Could it be valves Link to comment Share on other sites More sharing options...
Raley Posted October 20, 2011 Share Posted October 20, 2011 if it has good compression, its not valves (unless the cam is broke, but you wouldn't be running then). it MIGHT not be getting spark when its actually in the hole... (bad ground). but thats rare. id guess its fuel not getting into the cylinder.... Link to comment Share on other sites More sharing options...
willyj Posted October 21, 2011 Author Share Posted October 21, 2011 I swapped injectors with another cylinder and it didn't change Link to comment Share on other sites More sharing options...
Raley Posted October 21, 2011 Share Posted October 21, 2011 well the actual injector could be good, but wiring to it could be bad... Link to comment Share on other sites More sharing options...
