philostow Posted November 6, 2011 Share Posted November 6, 2011 I've had the check engine light came on several times in the past 6 months on my 98 Accord (4cyl). It always indicates that the O2 sensor is at fault. Replaced both sensors and engine light came on again a few months later indicating same problem. This time my mechanic says its the catalytic converter. The car has 140,000 miles. Questions: Should I get a new mechanic? Should I replace the catalytic converter? Might the problem be something else? Maybe the check engine light is faulty? What risk is there to the occupants of the car if I don't replace the catalytic converter? Thank you. Link to comment Share on other sites More sharing options...
Raley Posted November 6, 2011 Share Posted November 6, 2011 well, in the order of your questions no, yes, yes, doubtful, stranded. Link to comment Share on other sites More sharing options...
2slowCB7 Posted December 3, 2011 Share Posted December 3, 2011 Lol Im with Raley on this one. Its possible that the cat is bad making it get extremely hot where the O2 sensor is causing it to keep throwing the check engine light. Check to see if that car has a AFR sensor...idk what years have em and which ones dont. Link to comment Share on other sites More sharing options...
