Daniel Covarrubias Posted February 5, 2012 Share Posted February 5, 2012 After check engine light turns on car just dies...have to pull over and keep trying to crank it...eventually it will turn on but same problem happens when I step on it.. I'm thinking its the main relay or maybe just the map sensor.. Link to comment Share on other sites More sharing options...
Daniel Covarrubias Posted February 5, 2012 Author Share Posted February 5, 2012 Drove my car this morning and ran normal.. no check engine or nothing... drove it for like 15 minutes.. I put a little sylicone yesturday on the map senor o ring... not to sure if that's the case... Any suggestions? Link to comment Share on other sites More sharing options...
Daniel Covarrubias Posted February 5, 2012 Author Share Posted February 5, 2012 Never mind.. it did it again...haha...this sucks... Link to comment Share on other sites More sharing options...
Raley Posted February 6, 2012 Share Posted February 6, 2012 what code is it throwing? Link to comment Share on other sites More sharing options...
Daniel Covarrubias Posted February 6, 2012 Author Share Posted February 6, 2012 Its throwing 7... which is tp sensor and also throwing 15 which ignition output signal or m/t clutch switch. Signal Link to comment Share on other sites More sharing options...
Raley Posted February 6, 2012 Share Posted February 6, 2012 fix them/replace tps. Link to comment Share on other sites More sharing options...
Daniel Covarrubias Posted February 6, 2012 Author Share Posted February 6, 2012 Fixed the tps .. still shuting off.. I was told I need to change the Ecu for the ignition output signal.. is that true.. Link to comment Share on other sites More sharing options...
