dark Posted February 25, 2012 Share Posted February 25, 2012 hello ihave honda acoord 1983 and i have problem with power starting ,which is some times the starting is easy and some times is hard to move !!! when it's hard and you turn it ,its seems like it's stuck and when you turn it by force its back to normal and as so. PLZ help!! Link to comment Share on other sites More sharing options...
Raley Posted February 26, 2012 Share Posted February 26, 2012 starting or steering... i am confused by the question. Link to comment Share on other sites More sharing options...
dark Posted February 26, 2012 Author Share Posted February 26, 2012 yes 'steering' :whip: Link to comment Share on other sites More sharing options...
Turtlehead Posted February 26, 2012 Share Posted February 26, 2012 yes 'steering' :whip: Check the power steeing fluid level and also check the reservoir immediately after you drive it and look for frothy air bubbles on top of the fluid in the reservoir. If you have bubbles then you have a bad seal somewhere in the system. Link to comment Share on other sites More sharing options...
dark Posted February 28, 2012 Author Share Posted February 28, 2012 Check the power steeing fluid level and also check the reservoir immediately after you drive it and look for frothy air bubbles on top of the fluid in the reservoir. If you have bubbles then you have a bad seal somewhere in the system. first thank you but there is no air baubles in the reservoir any another ideas? Link to comment Share on other sites More sharing options...
Turtlehead Posted March 13, 2012 Share Posted March 13, 2012 Sorry for the late response. Yes there is one other thing you can check and that is slide back each boot on the P/S rack and see if there is fluid. It there is fluid then the seal(s) on the rack are back and you either have to rebuild it or replace it with a re-man. Link to comment Share on other sites More sharing options...
dark Posted March 17, 2012 Author Share Posted March 17, 2012 no problem at all, and thank you for your responds yes there is is a small fluid leak on the right side of the rack ,its possible that is the problem ?? and thank you again Link to comment Share on other sites More sharing options...
jocvtrhythgd Posted April 23, 2012 Share Posted April 23, 2012 starting or steering... i am confused by the question. Herve Leger Outlet Herve Leger Bandage Dress Herve Leger Strapless Herve Leger Single Shoulder louis vuitton For Women Link to comment Share on other sites More sharing options...
